Old 02-23-2013, 08:26 PM   #136
jauringer
jauringer's Avatar
Member Number: 3117
Default Re: LD`s Custom Scout II
[quote=ihpartsjeff;22949]
A cut out valve cover shows a very close tolerance between itself and the rockers.
A little closer view.
I've heard others have had issues with these roller tips contacting the valve cover. Did you run into this issue? If so, how did you handle it?
Sick build btw,
thanks,
jason
72 Scout II 304 TBI/727-TF2/D20
jauringer is offline   Reply With Quote
Old 02-25-2013, 07:56 AM   #137
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
Sick build btw,
thanks,
jason
The baffles had to be removed from the inside of each cover and a much smaller one fabricated to keep oil from going up and out the breather hose. We also had to sand down some of the rocker arms on the edges to get that extra little bit of clearance. Ideally a 1/8" valve cover spacer with a gasket on either side would be best. I think Robert(jetfxr) had some made. He might have an extra set or can get you a set made??
IH Parts America - Owner
Binder Books
(530)274-1795
Old 02-25-2013, 08:10 AM   #138
jauringer
jauringer's Avatar
Member Number: 3117
Originally Posted by ihpartsjeff View Post
the baffles had to be removed from the inside of each cover and a much smaller one fabricated to keep oil from going up and out the breather hose. We also had to sand down some of the rocker arms on the edges to get that extra little bit of clearance. Ideally a 1/8" valve cover spacer with a gasket on either side would be best. I think Robert(jetfxr) had some made. He might have an extra set or can get you a set made??
Great (well, not great) but great info. That's what I wanted to know. My set will be here today so I wanted to be prepared for exactly what I'll run into. I'll be running a blank cover on one side and a arrestor/filler on the other. Spacer is not a 100%. Still working on that.
Thanks Jeff,
jason
jason
Old 01-19-2016, 11:47 PM   #139
mbergthold
Member Number: 7107
Are the serpentine belt mods available as a kit?
mbergthold is offline   Reply With Quote
Old 01-20-2016, 07:42 AM   #140
Michael Dimock
IH Parts America Sales Assoc.
Michael Dimock's Avatar
Member Number: 581
Not at this time. Someday in the future maybe, but keeping costs lower would be the problem. Thanks.
Workin' at IHPA
Old 03-08-2016, 11:59 AM   #141
Mark Pietz
Member Number: 2143
Just now seeing this build. What were the bucket seats?
Old 03-11-2016, 07:34 AM   #142
ihpartsjeff
Member Number: 1
Originally Posted by ldo_marlin View Post
seats are from a subaru baja.
Originally Posted by Mark pietz View Post
just now seeing this build. What were the bucket seats?
Binder Books
(530)274-1795
Old 03-11-2016, 08:21 AM   #143
Mark Pietz
Member Number: 2143
They look pretty decent and like they belong there.
