Old 02-12-2010, 07:51 PM   #16
ihwild
Member Number: 261
Default Re: Matt's Full Width Scout II
Is the turning radius reduced much by going full width or is it actually determined more by the tire width? What width are those axles and how far do the tires stick out? I am thinking of going to a 14 bolt ff rear axle or a Dana 60 ff if I can find one cheap enough. Until then I might put a locker in one of the axles I just don't know which one yet.
Rich
ihwild is offline   Reply With Quote
Old 08-03-2010, 01:01 PM   #17
1972ScoutII
1972ScoutII's Avatar
Member Number: 1224
Originally Posted by sr2dude View Post
I love that access sticker! Where did you get it?
I have searched high and low and cannot find one. I love it too
1972 Scout II
SBC350 700r4 NP208
Work in Progress
1972ScoutII is offline   Reply With Quote
Old 08-03-2010, 01:14 PM   #18
ihpartsjeff
Administrator & Owner
ihpartsjeff's Avatar
Member Number: 1
If there is enough interest we can have our in house sticker guru make these.
IH Parts America - Owner
Binder Books
(530)274-1795
Old 08-03-2010, 02:37 PM   #19
Hunter Gallant
Member Number: 2104
I would definitely buy one.
Hunter Gallant is offline   Reply With Quote
Old 08-03-2010, 05:14 PM   #20
1972ScoutII
Member Number: 1224
Originally Posted by ihojeff View Post
if there is enough interest we can have our in house sticker guru make these.
Do it I will even prepay!
1972 Scout II
SBC350 700r4 NP208
Work in Progress
Old 08-04-2010, 08:00 AM   #21
scoutdude80
Member Number: 217
I think my dualie would like one.
scoutdude80 is offline   Reply With Quote
Old 08-04-2010, 11:36 AM   #22
ihpartsjeff
Member Number: 1
We'll put it on the list of future items to make. Thanks for the input.
Binder Books
(530)274-1795
Old 08-27-2010, 05:02 AM   #23
6.9PoweredScout
6.9PoweredScout's Avatar
Member Number: 2192
Did he want the tires to stick out that much?? I have full width 60s under my terra with rims that have a lot of backspacing and barley 1/4 of my 37x12.50s stick out, if I use factory flares it'd cover all but an inch or so. Looks good,I like the cage and sliders. On my front 60 I just oblinged the centerpin bolt holes and it bolted right in.
-jon
1980 Terra Scout II
6.9L IH Diesel V-8
NP205
4.10 D60's SOA on 4" springs
37x12.50x16 Irok radials
'74 Scout II
soft top
392/AT
3.55 D44's
1973 25' Starcraft motorhome
IHChassis 392/AT
ALL HARVESTERS, ONLY HARVESTERS!
6.9PoweredScout is offline   Reply With Quote
Old 08-27-2010, 04:33 PM   #24
Scouty
Scouty's Avatar
Member Number: 8
Originally Posted by 6.9poweredscout View Post
did he want the tires to stick out that much?? I have full width 60s under my terra with rims that have a lot of backspacing and barley 1/4 of my 37x12.50s stick out, if I use factory flares it'd cover all but an inch or so. Looks good,I like the cage and sliders. On my front 60 I just oblinged the centerpin bolt holes and it bolted right in.
-jon
I wanted to use my 15" tires, so needed rims with a reverse 2.75" backspacing to fit on the 3/4 ton axles. As it sits, from the outsides of the tires it's 90" wide. After wheeling it like this the added stability in offcamber situations is great. I've been through some pucker factor situations in my 74 Scout that this one rolls right through with no concerns at all.
73 Scout II
74 Scout II
Scouty is offline   Reply With Quote
Old 09-27-2010, 11:57 AM   #25
Orange74
Orange74's Avatar
Member Number: 1579
We pretty much ripped everything out and replaced it with a Dana 44 front axle and GM 14bolt rear axle out of a 3/4 ton Chevy pickup. A cv rear driveline was installed along with a long travel front driveshaft.
Jeff how is the long travel drive drive shaft holding up do you know? I'm currently doing almost the same SOA axle swap on my Scout and when I look at the distance and the angle I don't see a long travel holding up.
So what I think I'm trying to ask is it just not worth the extra work and fab time to put a cv drive shaft up front, because a long travel works just fine?
74 Scout II, 345(TBI)-TF727-D300, D44 F/14Bolt R
Orange74 is offline   Reply With Quote
Old 09-27-2010, 03:23 PM   #26
ihpartsjeff
Member Number: 1
As far as I know Matt has had no issues with the front long travel shaft. Cv shafts are great for longer length shafts however they are tough to use on the front of a Scout II due to the short length and higher driveline angle. Really we go with cv's anytime angle will allow as well as transmission clearance. Most 727's allow little to no clearance for a cv type shaft.
Binder Books
(530)274-1795
Old 12-14-2010, 08:01 AM   #27
SR2dude
Member Number: 1433
Hey Jeff- a little off topic but any idea if those sweet stickers will be made? I want to slap some on my scouts!
SR2dude is offline   Reply With Quote
Old 01-05-2011, 08:14 AM   #28
ihpartsjeff
Member Number: 1
hey Jeff- a little off topic but any idea if those sweet stickers will be made? I want to slap some on my scouts!
I did get a copy over to my buddy Mike who does stickers but have yet to see anything on them. Still waiting myself.
Binder Books
(530)274-1795
Old 01-15-2011, 11:50 PM   #29
mike hayes
Member Number: 1623
Where did u get the scoop
mike hayes is offline   Reply With Quote
Old 01-17-2011, 12:43 PM   #30
nate46and2
Member Number: 1608
This is a simple question. When you install a Chevy full width front Dana 44 on a Scout II you said the front spring perches are about a 1/2 inch off from lining up. Do you just move the drivers side perch over or how do you get it to match up with the Scout II springs? Thanks
nate r spence
nate46and2 is offline   Reply With Quote
