Old 01-27-2010, 08:30 AM   #1
WesChapman
Member Number: 837
Default Tools list requirment for owning a Binder
I'm looking for a list of tools a person should have if they own a binder or other old vehicle. I was looking at my tool collection and realized it comes up short. I have some of the basics, like sockets, open & boxed end wrenches, channel locks, vise grips, screw drivers, torx, etc etc. I have a sears tuneup kit I bought for $5 at a yard sale. It is a metal case, containing a timing light, dwell meter, compression gauge with fittings, vacuum gauge, remote starter button and operations guide explaining how to use and what the results mean. Probably from the 70's? In my specialty tool bin I have a clutch alignment tool (work was throwing it away), a steering wheel puller, 3 legged gear puller, dvom, and mini fridge stocked with water & beer. I have an air impact, but my 2cfm dewalt compressor doesn't have the ompf to run it. I don't have torque wrenches, welder, parts cleaning capabilty or even a decent floor jack.
What else should I have? What do others consider an mel? (minimum equipment list)
1978 Scout Terra. 345, T-19 close, D-20, D44x2, 3.73
Previous IH's
1980 Scout II diesel
1962 Scout 80
WesChapman is offline   Reply With Quote
Old 01-27-2010, 08:49 AM   #2
MarkO
Member Number: 740
Default Re: Tools list requirment for owning a Binder
A roll of duct tape to keep things from moving that aren't supposed to move and a can of wd-40 to keep things moving that are supposed to move.
MarkO is offline   Reply With Quote
Old 01-27-2010, 08:58 AM   #3
Korllach
Korllach's Avatar
Member Number: 1098
Robogrips are sooo handy.
Korllach is offline   Reply With Quote
Old 01-27-2010, 09:17 AM   #4
kyleandhisIH
kyleandhisIH's Avatar
Member Number: 613
For my Scout II, one of the necessaries was found in the 1979 parts vehicle I obtained. This tool was a small t-handle spark plug remover, with universal joint near the socket.
For my power steering pump bracket, I simply can't get to the #1 plug with any combo of ratchet, socket, and extension. But after finding this tool, I no longer have to worry about it. It fits into a very narrow spot between battery and ps pump when on the #1 plug, and is the epitome of the word "specialty." it couldn't have been made 1/2" shorter or longer and still work.
I realize that the accessory setup isn't the same for everyone, but I just figured I'd mention this type of custom-fit tool. I couldn't change all 8 plugs without it.
kyleandhisIH is offline   Reply With Quote
Old 01-27-2010, 09:25 AM   #5
RobertC
Member Number: 517
Flare-nut wrenches - for fuel / brake line fittings
"pickle fork" -- to separate tie-rod ends / ball joints from the arms.
If you decide to buy torque wrench(es), I would not skimp by buying the cheaper versions -- buy a craftsman, snap-on, etc
floor jack -- make sure you buy one with enough capacity (and safety margin) to lift ihs.
Same for jack stands.... Some look really "cheap" to me nowadays...
Large bench vise -- see if you can find a really old American made one. Maybe the cheap chinese are made better now, but the one I have is "pretty sloppy" compared to the old one my corvair mechanic had.
I do not do much work, but I have used berryman's carb cleaner (spray can - not very "friendly" - wear eye protection) to clean off the outside of carbs (off the vehicle).
Old 01-27-2010, 09:31 AM   #6
Michael Mayben
Michael Mayben's Avatar
Member Number: 10
Great thread idea man!
A mityvac hand vacuum pump is essential!
The tune up kit you described is an excellent score for working with oldskool stuff!
And one of those el cheepo "probe"-type stethoscopes from harbor freight. Same for one of the very inexpensive infrared thermometers.
A front hub nut socket for a 4x4 axle app.
A "cotter pin puller" is an essential for all kinds of work other than pulling cotter pins!
Let's keep this one going but keep in mind the budget restraints we all face and always consider bang-for-the-buck! We're talking typical handy-dan kinda stuff, not pro-level unless the job at hand indicates otherwise.
http://vimeo.com/8149690
Old 01-27-2010, 10:05 AM   #7
Eric VanBuren
Member Number: 544
A copy of the factory shop manual that matches your rig.
A bfh or big flippen hammer.
Eric VanBuren is offline   Reply With Quote
Old 01-27-2010, 11:47 AM   #8
RobertC
Member Number: 517
You should be able to buy a universal joint separately to match your socket set (3/8" drive, I assume).
Still a "pain", but easier...
The 3/8" drive socket set that I bought in the 70's came with one.
Actually, universal drive sockets in a couple common sizes ( like7/16", 1/2", 9/16") are useful depending on the vehicle / engine you are working on...
Old 01-27-2010, 01:48 PM   #9
WesChapman
Member Number: 837
Originally Posted by robertc View Post
flare-nut wrenches - for fuel / brake line fittings oh yeah! I forgot about these. I will also need a tubing bender.
"pickle fork" -- to separate tie-rod ends / ball joints from the arms. oops, forgot, I have one of these.
If you decide to buy torque wrench(es), I would not skimp by buying the cheaper versions -- buy a craftsman, snap-on, etc good to know. Was looking at a craftsman
Floor jack -- make sure you buy one with enough capacity (and safety margin) to lift ihs.adding to my shopping list
Same for jack stands.... Some look really "cheap" to me nowadays...forgot I have these to. Work was getting rid of them. 6000 capacity.
Large bench vise -- see if you can find a really old American made one. Maybe the cheap chinese are made better now, but the one I have is "pretty sloppy" compared to the old one my corvair mechanic had. going to need a bench first
I have a list now to leave around the house where the wife can see it.
Previous IH's
1962 Scout 80
Old 01-27-2010, 01:53 PM   #10
WesChapman
Member Number: 837
great thread idea man!
A mityvac hand vacuum pump is essential! adding to my list.
And one of those el cheepo "probe"-type stethoscopes from harbor freight. Same for one of the very inexpensive infrared thermometers. never even thought about these, but, yeah, I need them!
A front hub nut socket for a 4x4 axle app.you mean, using a socket extension and a hammer is the wrong tool? (adding to shopping list)
A "cotter pin puller" is an essential for all kinds of work other than pulling cotter pins!never seen, but adding to list
Excellent! Keep em coming, my birthday is in May and my wife thinks I'm the greatest guy ever. (well I keep telling her that anyhow)
Previous IH's
1962 Scout 80
Old 01-27-2010, 01:56 PM   #11
WesChapman
Member Number: 837
Originally Posted by eric vanburen View Post
a copy of the factory shop manual that matches your rig.
I have a 2lb & 8lb. I have used them both on the terra. "flippen", yeah, that's the word I use to.
and I have a shop manual; best Scout "tool" I have ever purchased.
Previous IH's
1962 Scout 80
Old 01-27-2010, 01:58 PM   #12
brained
brained's Avatar
Member Number: 777
Yin to your yang:
a big breaker bar (hi lift handle works)
1963 80, 196 with EDIS, Spartan/PowrLok D44's SOA on 33's. Driven Daily.
brained is offline   Reply With Quote
Old 01-27-2010, 02:22 PM   #13
WesChapman
Member Number: 837
Originally Posted by korllach View Post
robogrips are sooo handy.
Checked out the website. Interesting, and not expensive.
Previous IH's
1962 Scout 80
Old 01-27-2010, 02:24 PM   #14
WesChapman
Member Number: 837
Originally Posted by brained View Post
yin to your yang:
Completely forgot about my hi-lift jack and 22ton bottle jack. Cool, I have more tools (toys) than I thought.
Previous IH's
1962 Scout 80
Old 01-27-2010, 03:18 PM   #15
Michael Mayben
Member Number: 10
Originally Posted by weschapman View Post
excellent! Keep em coming, my birthday is in May and my wife thinks I'm the greatest guy ever. (well I keep telling her that anyhow)
Or...send me your wife's email addy and I'll "help" her shop on her nickel!
I've been married four times so I know all about how to handle wimmin!!!! Just ask 'em!
