Old 02-19-2009, 02:12 PM   #1
scout-n-josh
scout-n-josh's Avatar
Member Number: 625
Default My '73' IH Scout II Off-Roader & Daily Driver!
1973 IH Scout II
IH 392 w/ 345 heads
TF 727 Auto-tranny
Dana 44's front & Rear
3.73 gears, Aussie locker front
Miller 211 locker rear
SOA Conversion
4" Triangle Leaf Springs
35" Boggers
Full Cage
scout-n-josh is offline   Reply With Quote
Old 02-19-2009, 04:21 PM   #2
Michael Dimock
IH Parts America Sales Assoc.
Michael Dimock's Avatar
Member Number: 581
Default Re: My '73' IH Scout II Off-Roader & Daily Driver!
Nice Scout! Are those 35x15.5 boggers? Throw on some new paint and that baby will be killer!
Workin' at IHPA
Old 02-19-2009, 05:30 PM   #3
Tiny Yokum
Tiny Yokum's Avatar
Member Number: 669
I can tell you don't like it very much.
IH propane 152
HVACR Specialist
Tiny Yokum is offline   Reply With Quote
Old 02-20-2009, 06:19 AM   #4
scout-n-josh
Member Number: 625
Originally Posted by michaeldimock View Post
nice Scout! Are those 35x15.5 boggers? Throw on some new paint and that baby will be killer!
The rubber is 35x14.5
1973 IH Scout II
IH 392 w/ 345 heads
TF 727 Auto-tranny
SOA Conversion
35" Boggers
Full Cage
Old 06-15-2009, 04:07 PM   #5
scout-n-josh
Member Number: 625
Added new pics in the first post.
1973 IH Scout II
IH 392 w/ 345 heads
TF 727 Auto-tranny
SOA Conversion
35" Boggers
Full Cage
Old 07-31-2009, 09:55 AM   #6
country boy
country boy's Avatar
Member Number: 1216
Scout-n-josh,
that's a sweet rig.
This might be a dumb question, but, I'm new here and also new to scouts.
I'm in sacramento, and just picked one up and I would like to find a 392 and a 4 speed to swap in place of the tired 345/ 727.
But I was just wondering, what are the benefit's to running a 345 head on a 392, and is it a bolt on deal ?
Also, do you know what vehicles came stock with a 392, so I can keep an eye open at the local p-n-p's ?
Thanks for your help, fred.
country boy is offline   Reply With Quote
Old 07-31-2009, 11:19 AM   #7
scout-n-josh
Member Number: 625
Hey fred! Thanks for the compliment! The 392 are typically found in a medium duty truck, like a school bus or dump truck. And the 345 heads up the compression from, iirc, 8 to about 9.5 lbs or so.
Happy scouting!
Josh
1973 IH Scout II
IH 392 w/ 345 heads
TF 727 Auto-tranny
SOA Conversion
35" Boggers
Full Cage
Old 07-31-2009, 12:35 PM   #8
Scoutboy74's Avatar
Member Number: 453
392's also can be found in the f/s pickalls. The 345 heads will only work on a non-improved cooling 392. There is a serial number cut-off on 392 engines between the ic and nic changeover. Also, you need to take into account which type of pistons the engine has, as in flat-top or dome. Heads that don't match the piston style can cause clearance issues. If you do a forum search, you should come across a recent thread which covered these issues in more depth. Imho, unless you already have some outstanding 345 heads ready to go, the tiny almost negligable bump in compression simply isn't worth all the bs. My advice is to either freshen up your 345, or find a suitable replacement 345/392 that is complete and go with that. If you do swap in a 392, you will need to retain your Scout II oil pump/pickup, oil pan, flex plate, starter spacer and motor mounts and swap them over to the 392. Also, not all IH engines were cast with the same motor mount bosses. Before you plunk down money on one, be sure to verify that it's been drilled to accept the sii mounts that are near the front of the engine on either side.
Old 01-07-2010, 09:17 AM   #9
scout-n-josh
Member Number: 625
Have made some recent progress on the ol girl:
The topper and the rims are gonna get painted a semi-gloss black yet.
This was just last night:
1973 IH Scout II
IH 392 w/ 345 heads
TF 727 Auto-tranny
SOA Conversion
35" Boggers
Full Cage
Old 10-09-2012, 06:41 PM   #10
scout-n-josh
Member Number: 625
Wow, been awhile since my last update. Since my last post I have made some updated/mods to the Scout. Went to a 1-ton drivetrain, dodge d60 cut & turned front, cross-over steering, 14bolt rear, 5.13 gears and 39.5 rocks. Used Jeff's front spring hangers and some other IH only parts. I'd love to do a write-up build-up sometime when I hopefully get some time. Here's some recent pics:
Looks like I'll have to trim just a bit more...
Lol...the girlfriend driving the Scout:
1973 IH Scout II
IH 392 w/ 345 heads
TF 727 Auto-tranny
SOA Conversion
35" Boggers
Full Cage
